DX контур
Тема в разделе "Геотермальные тепловые насосы", создана пользователем kolyakm, 16.02.14.
  1. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    Вот один пишет:
    There are new ways to install ground loop systems. One of the most efficient is the where the coolant is directly fed into copper ground loops instead of using a heat exchanger. This avoids the energy cost of the pumps needed for heat exchangers. The new system drills holes from a single point in a star pattern at 45 degrees down with 3" holes at about 100 foot depth using copper pipe. The savings is on the drill cost and the grouting for 3" holes instead of 6" holes. This is best for retrofits since the yard is not torn up by placing the drilling equipment (holes) in several locations.
    This is a new technique and even though it should cost about 1/3 less for the system the installers are charging 20% more since the system is more efficient. This type of price gouging is common in the HVAC industry where a more efficient heat pump may cost the installer 500 dollars more he will bill the customer 2000 dollars more.
    If one were industrious he could start a company with the new drilling systems and undercut the competition at the same time increasing the number of cost effective systems installed. It is a good way of making 250K a years while helping the environment.
    А другой отвечает:
    gaucho: Unfortunately these systems have proven they are limited. My experience with these systems result in 50% failures. The construction of the outside loop, getting the oil back, taking care of the copper in the ground varies on ground content, hasn't proven to be consistant. Refrigeration is a touchy subject and moving refrigerant around takes a lot of care. The traditional loop works. It's easy to move water. The saving realized isn't any better than It sounds great but to the masses it is not ready for prime time. I would embrace it otherwise.
    Oil is used to move the refrigerant around and lubricate the compressor. It is direly important to bring the oil back to the compressor. My assesment is realized from 30 years experience manufacturing installing and now distributing geothermal heat pumps. I have seen many law suits, some work some do not. When they do not work it is a mess. I could give you names of people where it works and a comparable list of those that haven't. Most involved are very small manufacturers. So there isn't a whole lot of mony available to help. On paper it almost makes sense. But I have yet to see a company installing, distributing or manufacturing survive a long period of time. Those that do survive must supervise the installation very carefully.
    Мож я чет ни так понял, тоды пардон. :hello:
  2. enviro
    enviro
    enviro
    New york
    Ага один чувак нашёл брошюрку и излагает её своими словами другой 30 лет занимается продажей систем с 50% проблем и отсутствием производителей. круто однако :)
  3. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    Там есть и возражения (сразу не усек) ...
    You have talked about oil and yet I cannot find where oil is used in the process. Where do you get your data on inconsistency of the system? How can the system be inconsistent when a guarantee is provided? You seem to throw out a lot of negatives and yet you provided no links to support your assertions. You are also incorrect when you say that the system can only be used with the one it was installed with. The compressors can be replaced without effecting the ground loop. As a matter of fact the ground loop is 1/2 the cost and can last well over 50 years.
  4. enviro
    enviro
    enviro
    New york
    С бутылками тема мутная. вроде должно работать а сертификацию 4 год не могут получить. по этой причине продали их очень мало да и то с подачи местной лонг айланд электро компании которая освободила именно этот продукт от обязательной сертификации так как хозяин бутылочного цеха с ними был связан. да и размеры бутылок домохозяйкам не нравятса
  5. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    @enviro,согласен все это выглядит бредово, но тем не менее это передавая страна, где типа ТН ставят более 100000 шт. В год ...
  6. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    Хозяин похож на армянина - итальянца ... Способный ;)
  7. enviro
    enviro
    enviro
    New york
    Вон у вас дед и мастер тепла клепает эту лабуду у нас ертлинки и другие 3 конторы лепят и всё работает. ну бывают промахи и косяки но думаю не больше чем с другой холодилкой. счас забросил раньше много её ставил вывод таков что инструкции лучше читать до монтажа а не после и будет работать. а выгоды в cop перед обычной геотермалкой если воду греть нет.
  8. enviro
    enviro
    enviro
    New york
    Хозяин у них умный да и особенности бизнеса по американски таковы :) во у меня клиент энерго сберегающие панели делает взяли в партнёры астронавта бывшего толку от него ноль зато народ теперь доверяет космонавт же не обманет так и с бутылками :)
  9. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    Я брал в партнеры генерало, не помогло ... Видать у нас им не верят :):)].
  10. Альтермолог
    Альтермолог
    Альтермолог
    Это?
    А есть что ни-ть на русском?
  11. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    @Альтермолог, оно "чудо" ... На русском наврятли, да там вроде и так все понятно .
  12. Альтермолог
    Альтермолог
    Альтермолог
    Для меня пока темный лес.
    Мне на русском в холодилке много чего непонятного, а на аглицком подавно.
  13. heatingmaster
    heatingmaster
    heatingmaster
    Таллин
    По холодилке достойно и по русски изложено в ОСНОВЫ ХОЛОДИЛЬНОЙ ТЕХНИКИ (Рой Джорж Доссат) - как-то так
  14. heatingmaster
    heatingmaster
    heatingmaster
    Таллин
    Боитесь невозвратна масла-ставьте маслоотделитель из серии helical
  15. Mazzar
    Mazzar
    Hellstoker
    Mazzar
    Hellstoker
    Это пусть пендосы бояться ...
