Скандинавская каркасная флудильня
Тема в разделе "Каркасные дома", создана пользователем Паханычъ, 17.10.14.
  1. dimex
    dimex
    dimex
    А если не напрямую?
  2. Plotinum
    Plotinum
    Plotinum
    каркас-мембрана-вентзазор-ОСП-мой ответ американской классике в скандинавских условиях.
  3. Паханычъ
    Паханычъ
    PahanTalo
    Паханычъ
    PahanTalo
    ВеликоНовгородская
    @Dan!la, Выкинь фотки из блогов где тебе не понятно.
    Чтобы реально посмотреть.
  4. logi2121
    logi2121
    Да, я действительно Окнороб.
    logi2121
    Изучая скандинавские научные труды:
    Про масло масляное МДВП + мембрана.
    Намокание МДВП при строительстве- на последнем месте.
    На первом - непродуваемость.
    2.4 Norwegian approach- double air barrier
    In Norway, the demands on light-weight timber framed building envelope performance is
    similar to that in Sweden. However, in some cases there has been an increased focus on
    carefully sealing not only the interior vapour barrier but also the exterior wind barrier
    (Solvang & Handal Bjelland, 2011).
    In this case the wind barrier then becomes an important factor in the overall airtightness of the
    building envelope (Blom & Uvsløkk, 2012) which can now be said to possess both an exterior
    and an interior air barrier. The wind barrier often constitutes of a sealed water and wind
    resistant board or a sealed water and wind resistant rolled textile. A method which is
    becoming increasingly popular is the so called double wind barrier, meaning that both rolled
    textile and board are used simultaneously (Relander, et al., 2011).
    Defining the wind barrier as air tight allows for airtightness measurements to be made at an
    earlier stage of the construction process as the exterior wind barrier is mounted immediately
    after the completion of the structural framing. Such preliminary measurements of airtightness
    have become increasingly common in Norway. It has been proven possible to meet the
    building code requirements on airtightness with only the wind barrier mounted (Holøs &
    Relander, 2010). However, it cannot automatically be assumed that the final measuered
    airtightness of the finished building (after the installation of the interior air/vapour barrier)
    will be improved over the preliminary measurements since additional penetrations may be
    introduced either intentionally or accidently (Holøs & Relander, 2010). Additionally, the
    practise of carefully sealing the exterior wind barrier is beneficial as this layer provides
    effective weather protection during the construction phase.
  5. Паханычъ
    Паханычъ
    PahanTalo
    Паханычъ
    PahanTalo
    ВеликоНовгородская
    @Plotinum, Забудьте вы про это ОСП.
    И без него нормально скандинавоколотили.
  6. dimex
    dimex
    dimex
    А Вы реально так делали уже? Я в плане жесткости каркаса если ОСП на обрешетке.
  7. Plotinum
    Plotinum
    Plotinum
    Можно, утром почитаю? Пино Гриджио уже в сон клонит:):son:
  8. Паханычъ
    Паханычъ
    PahanTalo
    Паханычъ
    PahanTalo
    ВеликоНовгородская
    Ну дак это и ежу ясно.
    Это ты всё мостики холода ловил у обрешётки.
  9. Plotinum
    Plotinum
    Plotinum
    Поиск на форуме-Агалатово,в краю аистов. Или через профиль.
    По каркасу скакали до ОСП.
  10. Victor_G
    Victor_G
    Ломать - не строить
    Victor_G
    Ломать - не строить
    Череповец
    А ты щас все это по-русски говорил-спрашивал? Я про аистов и проч...
  11. logi2121
    logi2121
    logi2121
    И это тоже упоминается. Не сцы (с)
    Я щас погрузился в эту научную литературу, реальные тесты, жуть как интересно.
    Уже дочитал до того, что голая мембрана снаружи вместо изоплата - гомно на палочке, а не бюджетное решение.
    Погружаюсь дальше в шведскостроительный институт. Мырьк.
  12. Puzan3011
    Puzan3011
    Деревня Хапо-Ое
    Puzan3011
    Деревня Хапо-Ое
  13. Паханычъ
    Паханычъ
    PahanTalo
    Паханычъ
    PahanTalo
    ВеликоНовгородская
    А я же говорил, чтобы все шли на СИНТЕФ.
  14. logi2121
    logi2121
    logi2121
    А я не на СИНТЕФе.
    В данном случае эта так сказать организация является тормозом прогресса.
    Она рекомендует sd 10, а многие смарт-мембраны и VCL имеют меньшее сопротивление.
    Заодно узнал, что шведские учёные считают шведских рабочих жопорукими. :)]
    Небрежно клеют палителенку и протыкают её, падлы. 30% шведских каркасников жилого сектора имеют гнилостные разрушения.
  15. Puzan3011
    Puzan3011
    Деревня Хапо-Ое
    Puzan3011
    Деревня Хапо-Ое
    Кого штудируешь?
